Thermal paste them to the inside of a pice of Al pipe square, hex for 3 searies. then run your hot pipe through the middle. Add some cement for filler .Add a layer of 1/8" foam between the filler and the teg. like the flexable sheet stuff they wrap new dvd player's in . This will vaporize out during the brakein period leaving a small air gap to alow for thermal expansion of the chip sets. Also the cement would act like a capacitor, slowing and evening out the temperature spikes.
Also changing from direct transfer to IR only
Side effect that hasn't been bought up yet .
It will keep charging when you turn off the car ,the exhaust is hot for a long time after shut down, this may make up for some of the shprt commings. .Active cooling may be necessary for cool down.
Would just after the catalytic converter be the best place as it is a constant temp when active.? With good temperatures at low engine load.?
The average light off temperature at which the catalytic converter begins to function ranges from 400 to 600 degrees F. The normal operating temperature can range up to 1,200 to 1,600 degrees F. But as the amount of pollutants in the exhaust go up, so does the converter's operating temperature.
Sorce
https://www.google.com/url?sa=t&sour...EReJtF7R359yJA
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
