Old 07-27-2017, 04:39 AM   #35 (permalink)
serialk11r
Originally Posted by gumby79 View Post
Would just after the catalytic converter be the best place as it is a constant temp when active.? With good temperatures at low engine load.?
Hmmm, that's a good point. It's not constant temperature as almost all the fuel is burned by the time it enters the exhaust system, but the catalyst will definitely reheat it a little at lower load when the combustion efficiency is lower.
I think residual engine coolant should be enough to keep the TEGs from overheating once the car is off. A metal pipe has very little thermal capacity.
