Old 07-27-2017, 02:33 PM   #11 (permalink)
Stacygifford
Eco Storm Chaser
Stacygifford's Avatar
Nemo - '87 Ford Mustang GT
90 day: 27.26 mpg (US)
K-sight - '02 Honda Insight
90 day: 39.24 mpg (US)
The other thing might be what air-baggers call 'laying frame'. You could even have ground anchors mounted in two opposite corners so you could drive onto some bare ground and sink 'em.
If it is THAT windy, I may have other problems such as lethal debris. We do a pretty good job of being able to stay out of Immediate danger
https://www.instagram.com/txstormhunter/
If you want to see a few of my photos.
The converter gets loaded up with NOx and the ecu runs the engine rich every so often to regen the anti-NOx catalyst.
With out that regen the converter loads up with NOx and then the NOx blows straight through.
I would just use a normal converter.
http://ecomodder.com/forum/showthrea...urn-35095.html
That is a good point, I may be able to account for that in the tuning of my ECU, but I will need the NOX sensor working to know for sure.
I may wind up just keep the stock Cat.
The Following User Says Thank You to Stacygifford For This Useful Post:
freebeard (07-27-2017)
