Originally Posted by RedDevil
I don't think it is necessary to cool the TEGS after key-off.
Once the engine stops the heat sinks will cool them down quickly even if the power drain is cut off.
The engine generally won't be at full blast shortly before cutoff. I don't park at WOT
WOT to park no no agreed. The cat starts working minutes after start up and is working for some time after shut down till it gets under 6-800f . Theas have started many fires from people driving at slower than ecomodder speeds , was a major problem when they first came out. Finding the happy spot or controlling the hot side temp is the problem the high temp TEG are too spendy and 12-1600f is way too hot .
If your cooling pump or fan used say 10% of power production then why not let it top up the battery recapturing more of the energy already invested? Cost /w is high at this stage of development, so by the eg in the beginning we are only able to use a fraction of whats needed. By charging 120% of running time the % just got bigger.
a way to extend cat heat/power production @900f add 1 drop fule. the cat will catalyze the pure hydrocodone yealding heat allowing (just a guess) 10-15mun extension of charge time per drop.alowing for 2-500% charge timeV drive time.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
