Old 07-29-2017, 05:29 AM   #3103 (permalink)
shaggythegangsta
Hello Guys, i'm back again and sorry about my very bad english.. ahah
first of all i got the motor running on dspic30f6010A.. and added a code for 16x2 LCD. because it is impossible to debug because the analog inputs for current sensing are also programming port inputs.
But now i need your help guys who already tested this controller.. and MPaulHolmes also yours ahah if you have some time.
details of hardware:
CURRENT SENSORS: LTS-25-NP
IGBTS: FGH40T120
IGBT DRIVERS: A3120 OPTOCOUPLERS
BUS VOLTAGE: 100V UP TO 22AMPS
ENCODER: 1000 PPR
MOTOR:
CONNECTION: DELTA 230V PHASE TO PHASE CONFIGURATION
KW: 2.2
RPM: 2800
POLES: 2, 1 POLE PAIR
COSFI: 0.85
NOMINAL AMPS: 8.6
1: How can i set pi-ratio parameter? how to find the best one?
2:how to set throttle mapping values? i'm using 4.7k potentiometer.
my current values are:
max-regen-position=0042
min-regen-position=0339
min-throttle-position=0539
max-throttle-position=0837
the problems with these values are:
1: the motor jumps to maximum speed (4000+ RPM) with minimum variation of potentiometer.. i checked the potentiometer and it is ok. i checked also the ADCBUF values these also are in 0-1023 int.
2: the motor turns only in one direction.. the other haf of pot range does nothing.
FOR NOW THESE ARE MY BIG PROBLEMS.. AFTER I SOLVE THESE WITH YOUR HELP GUYS I WILL TEST THE MOTOR UNDER LOAD HOPEFULLY..
My current Configuration:
motor-type=1
kp=08618 ki=00139
current-sensor-amps-per-volt=0040
fault-throttle-position=0005
max-battery-amps=0010 amps
max-battery-amps-regen=0002 amps
max-motor-amps=008 amps
max-motor-amps-regen=008 amps
precharge-time=0001 tenths of a sec
rotor-time-constant=023 ms
pole-pairs=001
max-rpm=03000 rev/min
throttle-type=1
encoder-ticks=1000 ticks/rev
pi-ratio=062
raw-throttle=0508
