Old 07-29-2017, 11:29 AM   #3105 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by MPaulHolmes View Post
Try this: After changing those resistor values, set it to max throttle, and then type config (noting where raw throttle position is). Then, set it to min throttle and hit config. I haven't tested anything with a pot rather than hall effect, but maybe thingstodo has. I would set the throttle max and min variables based on what you see when you do that test.
If you set your pot to minimum, type config and write down the number
Set your pot to maximum, type config and write down the number
Let's guess that you get 500 for minimum and 700 for maximum (based on your description). I'd change these numbers
max-regen-position=0042
min-regen-position=0339
min-throttle-position=0539
max-throttle-position=0837
to these numbers
min-regen-position=0510
max-throttle-position=1023
For testing, you would get a small amount of reverse, only the part from 510 down to 500. If I guessed wrong and your numbers are different, give yourself about 10 counts of reverse that you can get to just to show that it works.
You still have a deadband where the motor does not turn, from 510 to 539. It needs to be big enough that you can easily get the motor speed to 0
I doubt that your reading will go up to 1023 so you will get less aggressive acceleration for your testing, but you won't be able to get to max speed.
Have fun!
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
The Following 2 Users Say Thank You to thingstodo For This Useful Post:
MPaulHolmes (07-29-2017), shaggythegangsta (07-29-2017)
