Old 07-30-2017, 12:30 PM   #3111 (permalink)
shaggythegangsta
Originally Posted by MPaulHolmes View Post
same values as indicated on what schematic?
I mean here https://ibb.co/jvFKvQ
I already tried this configuration.. i get 4.7volt to 5volt
Adc values from 962 to 1020.. and throttle mapping just does not work..
Then i connected the potentiometer to anlaog input getting raw_throttle from 0 to 1023...
Now in the middle i have 0 throttle.. then it goes to max negative and max positive. So i think the throttle mapping now it ok.
But the motor turns only in one direction is it normal? When the throttle values is negative it should not be changing the rotation direction?
Other question is how can i set the maximum rpms? Because now it goes up to 4000rpms when thw throttle is maximum
And thanks guys for helping
