Old 08-03-2017, 01:12 PM   #36 (permalink)
smallscaleH2
Originally Posted by samwichse View Post
I like how his last calculation equated 1L of diesel fuel to 1L of uncompressed gaseous HHO.
ROFL!
Thread over.
Originally Posted by RedDevil View Post
One kilogram of uncompressed Brown's gas does not fit in the car, even if you'd utilize the entire passenger space. And that's a good thing. Any volume that's over a gram worth is dangerous.
I'm not sure where samwichse got the idea from that I compared diesel fuel to 1L of uncompressed gaseous HHO.
I only said that "I assumed you'd get about half the range of an electric car", given that you have high efficiency losses when generating HHo gas from a battery.
Also, I don't get why some of you seem to think that I need to store this amount of (uncompressed) gas in a single go onboard the vehicle. I wouldn't be using tanks remember, I would be generating it via an on-demand system (electrolyser). So I don't need to store much HHO gas at all.
Originally Posted by teoman View Post
I am no expert but you may have to use a spark.
Yes. I came to the same conclusion.
See https://ipnpr.jpl.nasa.gov/progress_...42-27/27BB.PDF
I think the best option here is just to mix plain hydrogen (not HHO) with a regular fuel in the combustion chamber. That doesn't clean up the exhaust emissions completely, but at least partially. So it would be an improvement, and I don't need to install a spark plug.
See here, here and here
Oh right, one more thing:
If we just look at the differences:
EV conversion: + motor, motor controller;
HHO-Diesel: + Diesel engine, cooling system, tranny, exhaust system, electrolyser, power regulator...
With a conversion, I mean you would have an existing (working) Diesel vehicle you'd convert. So you don't need to buy a new Diesel engine, exhaust system, ... then.
