Old 08-03-2017, 05:12 PM   #21 (permalink)
serialk11r
Originally Posted by Panther140 View Post
The parasitic losses while in V4 mode are less than the parasitic losses of the vehicle in V8 mode. The inertia of the pistons at a given speed does not change when you fire those cylinders. However, the side loading on them increases.
The pumping losses are increased in all 8 cylinders when the vehicle switches to V8 mode.
What's wrong? Press the gas harder when it goes into V8 mode, then it'll be more efficient.
The point of a hybrid system or supercharger/turbocharger is to add power efficiently, but here you already have a lot of reserve power so that's not what you want.
