Old 08-05-2017, 08:02 AM   #7 (permalink)
ar5boosted
ar5boosted's Avatar
In a gasser, it's all about how you fool the ECU to adjust the injection to go leaner when water injection is on.
Well, I opened the bonnet today on my V6 to inspect if I could find space for Water-Injection and it seems that I was in-luck.
Since it's a sucky V6 (a powerful one), 270hp or so it would be interesting to attempt a Water-Injection build on this car. The car was bought as a muck-around toy rather for any practical transportation use.
It's a 20mpg around town, 30mpg freeway. It would be good to get more.
On such a car it's worth doing. I'm pretty sure that hacking the IAT sensor is the way to temporarily go leaner. But the o2-sensors eventually reset during the calibration phase which I'm led to believe is running at constant speed 80kmh+. I've used o2-sensor extenders in the past, they did achieve a change in economy.
To come will be photo's of it having a Water-Injection system.
2003 Renault Scenic - 30% more power with no loss in fuel economy.
1991 Toyota GT4 - more economical before ST215W engine-swap.
previous: Water-Injected Mitsubishi ~33% improved.
future - probably a Prius
