Old 08-08-2017, 03:16 AM   #62 (permalink)
LioNiNoiL
EcoModding Wannabee
LioNiNoiL's Avatar
For the past three years, I've been running Prodigy (Yokohama) H/T "Light Truck" 51psi-rated P235/75R-15 tires on my Blazer at 40psi, recommended locally because heat here in Las Vegas is a much-bigger contributor to tire failure than anything else, and higher pressure reduces heat from less sidewall flex. Predicted high temperature tomorrow-through-Thursday is 106°F
"There's no tellin' where the money went"
-- Robert Palmer, "Simply Irresistible" (1988)
Last edited by LioNiNoiL; 08-08-2017 at 11:09 PM.. Reason: 35psi was Chevrolet recommended pressure
