Old 08-08-2017, 06:46 AM   #65 (permalink)
Frank Lee
Originally Posted by LioNiNoiL View Post
For the past three years, I've been running Prodigy (Yokohama) H/T Light Truck (LT) 35psi-rated P235/75R-15 tires on my Blazer at 40psi, recommended locally because heat here in Las Vegas is a much-bigger contributor to tire failure than anything else, and higher pressure reduces heat from less sidewall flex. Predicted high temperature tomorrow-through-Thursday is 106°F
If it's a P235 it's a passenger car tire. If it's a LT235 it's a light truck tire.
