Originally Posted by t vago
What injectors are you looking for? From RockAuto.com, the 2008 Cadillac CTS with the 3.6L engine uses Bosch 0280156300 injectors rated at 246 mL/min, and the 2012 Chevrolet Traverse uses a direct fuel injector. You might see some gains by swapping your CTS's injectors with the 12-hole ones.
yes, the CTS. How did you find the flowrate? I looked everywhere, nothing even in google searches was helping.
I have a suspicion that the injectors are no longer balanced, each bank has one injector that has a different pulse width than the other two in the same bank. On top of that, one bank is consistently 10% longer pulse width leading me to beleive it is also an O2 sensor problem. But i hate to drop that much cash on a hunch with no codes or misfires. Car has 167k on it, i drive 2500 miles per month.
