Originally Posted by t vago
Some updates -
The Dakota now has a set of these fuel injectors, and runs as nicely with them, as do both my Magnum and my Durango.
Finally filled up after the Magnum dinged on me today. Went 410.7 miles on 15.017 gallons, for a tank fuel economy of 27.4 MPG. The MPGuino now under-reports fuel consumption by about 1.4%, where it used to over-report by about 4%. The MPGuino reports that I got 27.5 MPG. Not quite the 20% I had figured (and had secretly hoped for, to be honest), but still...
This is a improvement of 11.6% from the previous tank (02 July fillup) in which the old fuel injectors were used, and an improvement of 4% from the immediate last full tank that I put in two weeks ago.
11.6% is good. You'd be hard pressed to get an 11% increase with other methods...my wheel covers were (only) worth 7%.
How did you determine these 0280156161 injectors are 12-hole? I'm coming up with nothing. Found them at
Bosch Fuel Injector Catalog Wholesale Prices No Charge for $25 each. If I could get the same results with my 4.7L, that'd be fantastic.
