Old 08-17-2017, 01:42 AM   #2 (permalink)
westygo
I simply used the factory attachment points, drilled holes at the bend points to eliminate the possibility of cracking and bolted in place. I bent the ends out to deflect flow around the front tires. Looks almost invisible, but does scrape parking curbs a bit.
ID:	22413   Click image for larger version
ID:	22414   Click image for larger version
ID:	22415   Click image for larger version
ID:	22416   Click image for larger version
ID:	22418   Click image for larger version
ID:	22419   Click image for larger version
ID:	22420   Click image for larger version
The Following 5 Users Say Thank You to westygo For This Useful Post:
aerohead (08-19-2017), BamZipPow (08-20-2017), Daox (08-17-2017), MetroMPG (08-17-2017), wyatt (12-13-2017)
