Old 08-17-2017, 03:20 PM   #205 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
The box frame is now screwed and glued:
I changed the profile taper slightly, to match the plan taper:
Hatch opening clearance:
The carrier platform is pretty stout, and the box will be bolted to it at four points 14" square. But, if it torques at all it should be pretty easy to add some bracing to the bumper cover or license plate attachment holes.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following 6 Users Say Thank You to Vman455 For This Useful Post:
aerohead (08-19-2017), BamZipPow (01-31-2018), Cd (03-14-2021), eco_generator (08-21-2017), MetroMPG (08-22-2017), Xist (08-22-2017)
