Old 08-19-2017, 12:00 AM   #7 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Originally Posted by LeanBurn View Post
No matter how high you lift...still drags the diffs and axles in the mud, rocks and air apparently.
I never understood this practice.
It's pretty simple, you fit bigger tyres to make room under the axles. You lift the body/ suspension to make room for the bigger tyres.
It's worth keeping in mind the usual caveat of not putting too much stock into the MPG claims of the non-hypermiler.
I have a TJ that runs the same engine/ drive train. I did the same basic swap from 225's to 31" tyres and I'm running ~15% over EPA. Brakes are fine although the stock parts only lasted around 20K miles. It will still pretty much pull there rear tyres off the ground in an emergency stop. You need to use more pedal pressure, that doesn't mean the brakes are poor, if you can still lock your wheels on coarse chip, you're fine.
I get the same 18+ MPG he did stock, but with a much less aerodynamic vehicle. Mine is for off road use only.
The gearing thing is also non-sense, you only loose acceleration in first and top gears, there are a stack of gears in between (yes there's added inertia but the 4.0 should be grunty enough for most everyone). In my six speed, first is still very low and top basically idles along at 30mph.
I'm guessing his is an auto and the higher rollout is causing more slippage at lower speeds and possibly not engaging the TC lock as much. Of course you don't buy an auto for MPG.
You can feel the bigger tyres beneath you, but a lot of that I put down to the front and rear live axles. You'll never get 'car like' ride and handling from a live front axle.
My next tyres will be at least 32's or possibly 33's.
