Old 08-24-2017, 06:49 AM   #36 (permalink)
arcosine
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
The nose is too blunt. Check out Velomobiles Coroplast and Recumbent Homebuilt groups on facebook and the Recumbents.com site.
https://www.facebook.com/groups/1564...ocation=stream
Originally Posted by The Toecutter View Post
I've been putting together an electric assist velomobile with the goal of approaching less than 10 Wh/mile at 30 mph on flat ground with the rider pedaling with an input of 100W. I want to make sure that I have the body streamlined to a decent degree. The first body, depicted in this post, is being made out of corrugated plastic. It is not good at making compound curves, and generally only likes to be folded in one direction. I came up with the design below based on the Rumpler Tropfenwagen and the lakester salt flats racers, with a bit of influence by the LeMans velomobile. After that is a picture of the trike as it exists today. Open wheels are a necessity in order to fit it in and out of my doorway, and the body width is as narrow as possible while still providing clearance for the steering bars and without the wheels scrubbing. I estimate a frontal area of 0.6 m^2, but I am hoping to get a 0.25 Cd or below. Better shapes will be built after this one, but this will be the starting point.
The drawing of the body is done to scale. 1 square in the blue grid is 100 mm.
- Tony
The Following User Says Thank You to arcosine For This Useful Post:
Grant-53 (08-24-2017)
