Old 08-28-2017, 01:16 AM   #3120 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by ScottyWarpNine View Post
Ok, that makes sense. I figured there was pre-compiled code, but was confused since I couldn't find it. Paul sent me a bunch of files (c files, header files) but no hex file that I'm aware of. I guess I need to track that down.
That's a bit strange. I've attached the latest one that I have on this message. I have source dated Jan 3 2017 but it has no hex file. The latest one that I have the hex file for is April 17 2016.
Does the Pickit 3 supply power to the board
Yes it does. I think that's how I loaded the firmware. Using the DC/DC supply works for debugging ... but there was something about loading firmware that I only used the PICKit 3 to power the board.
The file is too big to post as a zip file. I renamed it to an xls extension and it uploads ... but you will need to rename it to zip to use it.
I tried to add the hex file separately - unknown file type - sigh!
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
