Old 08-30-2017, 02:14 PM   #3122 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by ScottyWarpNine View Post
Programming...
The following memory area(s) will be programmed:
program memory: start address = 0x0, end address = 0x7fff
program memory
Address: 0 Expected Value: 40100 Received Value: 0
configuration memory
EEData memory
User Id Memory
Failed to program device
2017-08-29 21:34:43 -0400 - Programming failed
The device will erase but will not program or do the blank check.
What does your setup look like? I think there may be a cable that is too long.
I use the pickit 3 ribbon cable plugged directly into Paul's board. I don't remember if I need to use a male-male header ... I'll have to look tonight.
Prop the pickit 3 on a piece of insulating material, like perfboard or a ceiling tile. Then the USB cable goes to the laptop.
I have had similar problems when using a ribbon cable extender from Paul's board to the Pickit 3.
At that point, selecting the correct dsPIC is about the only config required. But I have never had a verify complete successfully .. which is a bit strange .. the erase and program work.
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
