The cost of a Life shouldn't be too high on a bike? My Fiat cost around $150 to do. If a single charge is enough for your daily needs, the alt-less is the way to go. Life should maintain voltage enough for all your systems to function correctly.
The main gain of an alt delete is you get a lot of low end torque and drivability.
