You could just cut circles out of coroplast and shove a metal rod into the corrugations, and glue it once its in place. Then bend the rod and you have a lever to push back and forth.
I did something similar with a grill block design I came up with:
http://ecomodder.com/forum/showthrea...tml#post343561
