Old 09-03-2017, 08:46 PM   #104 (permalink)
oil pan 4
The closer you can get to the intake runner the better with fumigation.
You don't need to add a carb to the mix. A carb would just be a restriction to a diesel.
I ran propane fumigation before the air filter years ago, only problem was some times I could smell propane. Once I relocated the injection nozzle to the top of the intake manifold, on the inside of the air filter the smell went away.
Isaac Zackary (09-04-2017)
