Old 09-04-2017, 09:14 AM   #10 (permalink)
CapriRacer
Tire Geek
CapriRacer's Avatar
Unfortunately, the image is misleading. It implies that you can get *Green Tires* - that is, tires will Low Rolling Resistance - AND also get better grip while maintaining good wear properties.
What the image doesn't explain is that tires with simple substitution of silica/silane for carbon black are WORSE for treadwear and the rubber compound has to be readjusted to get that treadwear back - AND most importantly - that tires with excellent wear properties are NOT going to be good for RR.
PLUS the term *LRR* is a relative term. It means *better for RR compared to tires with the same grip and wear properties*. A LRR tire can have worse RR than a conventional tire because the tread compound can be reformulated to emphasize any of those particular properties (at the expense of the others!)
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
The Following User Says Thank You to CapriRacer For This Useful Post:
JockoT (09-04-2017)
