This is part of my design process for determining where things in the enclosure need to go
Decisions made so far:
- weatherproof or splashproof enclosure
- the controller will be mounted to the bottom of the encosure, through a hole
- the liquid cooling stays outside the enclosure
- high voltage items on the left
- low voltage items on the right
- controller in the middle
- use bent and drilled buss bar connected to insulators where cables with lugs just won't fit
https://youtu.be/XGtsmmaMnUo
I likely made a bunch of assumptions as well - that I don't remember very well since it was OVER A YEAR AGO!
When did my todo list get this out of hand? Over a YEAR behind publishing video!
