If you dropped it with the torsion bars, the camber could be out, but you should be able to do a "visual" and see if the front tires look like they are standing straight and not all sprawled out like a whooped Econoline van.
As long as he got it in specs, the tires should not wear funny, but only you will be able to tell that over time.
GeoMetroforum.com - got mpg?
