Old 08-20-2008, 10:33 PM   #3 (permalink)
mwpiper
I believe an angled deflector is the right path. Not sure how a flat plate improves over the curved tire.
Consider gluing your attachments on. This avoids breaking the finish. There are many items that are solidly and essentially permanently attached with simple two faced adhesive strips. If the deflectors are attached under the rocker panel, even if you took them off the marred surface wouldn't show.
