Old 09-11-2017, 04:26 PM   #14 (permalink)
LeanBurn
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
As hypermiling is all about how little you can open the throttle body (less the TB is open, the less fuel is consumed.) a TB that is closed 95% with even a 1mm layer of film on it would have no bearing on fuel economy as it doesn't add to the restriction of the overall intake mass air. Its using a straw to breath in with then sticking the straw into a large cup vs xlarge cup, the amount of air volume being taken into the straw is the same.
Effect on performance, throttle response and correct operation....for sure.
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
The Following User Says Thank You to LeanBurn For This Useful Post:
JockoT (09-11-2017)
