I think your biggest limiter will be not doing a kill switch with how short and low speed your commute is. Aeromods won't help much. You could probably pump up your tires a little more. Technique and driving style will be your money makers. Just because you're doing certain driving techniques doesn't mean you're getting the most out of them or using the right one at the right time.
Do you have any instrumentation? That will help you a lot in determining what's working best for you.
