Old 09-12-2017, 08:45 AM   #4 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Things I would try:
Higher tire pressure - maybe try 45 PSI?
Block heater - I use mine all year
Disable the alternator - charge your battery at home every night, maybe add a solar charger
Make sure your brakes have minimal drag
Zero-toe alignment
0w-20 engine oil
Engine-off neutral coasting will be better than high gear fuel cut coasting - compression braking is still braking
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
Daschicken (09-21-2017)
