Old 09-13-2017, 10:30 AM   #3 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 38.64 mpg (US)
Start by looking at two cases:
Case 1: Assume a constant low acceleration to a speed. You reach that speed at a distance. Use the engine BSFC chart, gear ratios, and rear axle ratio to find fuel used.
Case 2: Assume a constant high acceleration to the same speed, then constant speed to the same distance as Case 1. Use the engine BSFC chart, gear ratios, and rear axle ratio to find fuel used.
Note that the engine efficiency (BSFC) varies with RPM and throttle opening. The variable engine efficiency is outside the scope of calculus I, so this problem cannot be solved using calculus I math. It would be a good problem for a class in numerical analysis, though.
And good luck with your calculus class. Calculus II and III are even more fun!
The Following 2 Users Say Thank You to JRMichler For This Useful Post:
Ecky (09-13-2017), Xist (09-13-2017)
