Old 09-15-2017, 10:34 AM   #1 (permalink)
jackbauer
jackbauer's Avatar
Tesla Powered BMW E31 8 Series
So some of you might already know about my E31 conversion as it's been going on 3 years now! Currently running a Siemens 1pv5135 motor and DIY inverter and 6 speed manual gearbox. Has been running very well the last few months but with the Tesla components becoming available and my work on the open source control boards progressing nicely I've decided to convert the E31. Again.
I had originally thought to use the small high efficiency drive unit but decided to go all in and put in the Large rear unit for 450hp+
Going to be getting some help and the use of a workshop and vehicle lift for the drive unit install as it will need some serious work done to the rear subframe and boot floor. Once the drive unit is in then I can start putting some batteries into that nice big empty engine compartment. Should make quite a fun car and test bed for the open source control board. Stay tuned
Name:	2017-09-12 19.33.24.jpg
ID:	22678   Click image for larger version
ID:	22679   Click image for larger version
Name:	2017-06-13 14.40.09.jpg
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
The Following 4 Users Say Thank You to jackbauer For This Useful Post:
Daox (09-15-2017), MetroMPG (09-15-2017), oldtamiyaphile (09-15-2017), thingstodo (09-15-2017)
