Old 09-17-2017, 10:46 AM   #8 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
Loss of range in winter is mostly due to early compliance car EVs using electric resistance heaters. My Spark EV uses about 1/3 of the battery to supply a modest amount of heat. On the other had running the A/C in the summer only consumes about 5% of the battery on the same commute. The Bolt and all modern EVs use a heat pump for HVAC which is MUCH more efficent than resistance heating. Problem solved.
