Old 09-17-2017, 03:54 PM   #9 (permalink)
vskid3
vskid3's Avatar
Civic DX (sold) - '97 Honda Civic DX
90 day: 34.15 mpg (US)
GTO (sold) - '04 Pontiac GTO
90 day: 22.62 mpg (US)
Green Brick (sold) - '06 Ford Escape Hybrid
90 day: 31.93 mpg (US)
The Bolt and all modern EVs use a heat pump for HVAC which is MUCH more efficent than resistance heating. Problem solved.
The Bolt actually uses a resistive heater, as does the i3 REx (gas tank goes where the heat pump fits on the regular i3). Not sure about others.
Preheating while plugged in helps save the battery for driving. I'm curious to see how my Volt does in the cold. I should be able to still do most of my warm weather EV trips on battery alone in the cold if I can keep the ICE from turning on to provide heat. The biggest difference is I'll probably want to plug in whenever I'm at home instead of just at night like I currently do, to keep the battery topped off and warm.
Camry Thread
E-Bike Thread
