Old 09-19-2017, 04:38 AM   #9 (permalink)
kurzer
kurzer's Avatar
Knut - '07 Toyota Prius
90 day: 50.9 mpg (US)
Santa - '00 Hyundai Santamo
90 day: 29.07 mpg (US)
Originally Posted by Daschicken View Post
You should also be able to adjust the idle speed on that NA miata. The bros NB miata is too new for that. AND we can't adjust the ignition advance! Enjoy the adjustability of your old miata! His NB miata idles at 900-1000 rpm.
to do the idle, u have to connect 2 pins in the engine bay. this will show the real setting. but there is a trick. if the rev is falling to slow while shifting, u can reduce the idle air. drops it to fast, rise it a bit.
i hope u will set the mixture somewhat leaner, as i suggested in the the other thread. u will love it, i promise. miatas running verry rich in open loop.
kurzer Gruß
Prius II
Hyundai Santamo
The Following User Says Thank You to kurzer For This Useful Post:
MetroMPG (09-19-2017)
