Originally Posted by ctmaybury@yahoo.com
I'm already doing lpg fumigation with good results.
What vehicle are you doing the LPG fumigation? Is it Diesel-powered?
I think you would need high pressure and good nozzles to get the best atomisation you can. Big drops of water wouldn't help much.
Atomisation is the key, and adding some alcohol (methanol, ethanol, whatever) usually also helps vaporising the water at the intake stream.
If you drop the combustion heat with water, you pobably increase the hydrocarbons in the exhaust and reduce the nitrogen oxides.
Sure it reduces the NOx, but any increase in HC emissions is quite arguable. Dropping the intake temperature with water injection usually leads to a denser air flow, with a higher concentration of oxygen which then leads to a more accurate combustion. OTOH we also may remember it's likely to also involve a leaning of the air/fuel ratio, while the water helps cooling down the pistons instead of relying on a richer mixture for that matter. Anyway, since the water has a higher thermal conductibility than air, it retains some heat that would otherwise be wasted instead of turned into motion.
