Old 09-21-2017, 01:34 AM   #5 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
First panel is done.
Chrome wrap, 10mm fluted polycarb (intended for roofing), panel on top. All fixed with VHB tape. I ran a strip of alluminum over the front of the panel just in case. It's screwed to the factory roof rack points (I have 10 mounting points so I can spare a couple).
Top Tip: Flute polycarb is much cheaper in short pieces than in longer lengths. A 2400 long sheet was $120, I bought 3x1200 sheets for $60. It means one join under each panel, not a big deal.
The temperature of my roof is the same under the panel as it is without, so happy with that.
So far I'm seeing approximately 0.2l/100km gain. Less than I expected, but then that's why I ordered two panels. I wanted to run a single panel for a while just in case the second panel wasn't necessary. As we head towards summer, the gain can only increase.
As the panel smooths my ribbed roof for only a tiny frontal area increase, I should have better aero too.
Name:	IMG_20170911_113825 - Copy.jpg
ID:	22729   Click image for larger version
Name:	IMG_20170912_152534 - Copy.jpg
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
freebeard (09-21-2017)
