I recently came across a thread on a Jazz/Fit web site (struggling to find it or I would have posted a link) where someone had a similar issue. After doing all that you have done they tried a leak down test and found a slightly bent intake valve. Their compression test had not revealed the problem.
I am not saying you have a bent valve, just pointing out that a leak down test often reveals issues that a compression test doesn't show up.
