Old 09-22-2017, 07:34 AM   #32 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Originally Posted by AdrianD View Post
Later edit:
About the soot on the tailpipe, as far as I know Miatas are tuned rich from the factory. If you want to get that out of the way, take a look at Speeduino, open source ECU. Cheap, already available with plugs for the Miata wiring harness and tunable with the same software as Megasquirt.
There's also the air-flow meter adjustment that will lean it out.
Oh and between my cleaning the ground connections and installing a heated O2 sensor, my tail pipe isn't quarter as sooty as it used to get.
