Power to a positive displacement pump is Hp = GPM X PSI / 1714. That's the theoretical power at 100% efficiency. Divide by efficiency to get actual shaft horsepower.
If you measure flow rate at some RPM, and find the drive ratio of the pump (pump RPM vs engine RPM), then you can calculate oil pump horsepower as a function of engine RPM and oil pressure. That would be interesting information.
