Yep, you are %100 correct.
My car was NA gasoline fueled, converted to LPG. Lpg had its own injectors and was injected in gas form.
But the I think his intent is to have the lpg supplement the diesel a little bit. A bit like NOS in which case the cooling effect would be desirable in my opinion.
As rooster mentioned wlsewhere injecting LPG in liquid phase can be a bit tricky when used as primary fuel. It can freeze some components linke valves etc.
