Injecting propane after the intercooler is better.
The hotter the intercooler (delta temperature) the more thermal energy it will reject. And you will have a cooler charge.
Propane will instantly turn gasseous so it will not be a problem.
As long as your setup has enough distance or continuous injection for full mixing.
