Old 09-24-2017, 12:59 PM   #36 (permalink)
stovie
the green machine :P - '97 Jeep Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Thee s10 - '00 Chevy S10
90 day: 24.27 mpg (US)
Freedom - '05 Kawasaki Ninja 250EX
90 day: 75.55 mpg (US)
I was thinking you could create a new header for the car that utilizes the concept a propane fridge uses, having it take the heat from the exhaust to vaporize the ammonia then having it condense on the cold side of the peztier module?
By having a container inside the header that the exhaust flows around holding the ammonia, while the outside wall of the exhaust is directly touching the hot side of the peztier I could create more power without added requirements!?!
From what I understand a normal propane fridge only needs around 250 f to properly function??
