Old 09-26-2017, 10:20 AM   #3123 (permalink)
mitsui
Hello guys,
I have the dip version of the board and software with manual pi-testing. Even though i configured my throttle values and keep the pot at deadzone, there is a small amount of current going through my motor which moves the shaft back and forth slowly. My data stream shows Idref, throttle, mechanical speed values are all 0 but Id value keeps changing between +-3A. Motor spins with vibration if I throttle it.Has anyone had a similar problem before? DC bus voltage is output of 3-phase rectifier btw, could it be a leakage problem?
