Old 09-27-2017, 01:29 PM   #5 (permalink)
Daox
The top gear ratio is the same on the 5 and 6 speed transmissions on the Vibe. It is .725:1. The final drive is taller on the 5 speed though. Therefore, cruising on the highway you would be better off with the 5 speed.
You could swap in a C59 from an 98-02 Corolla. It has .725 5th gear and 3.722 differential gearing.
The Following 2 Users Say Thank You to Daox For This Useful Post:
MetroMPG (09-27-2017), niky (09-29-2017)
