Old 09-27-2017, 10:43 PM   #20 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Could definitely use another gear in the 1-2-3 range.
Yeah, me too. The way I drive, I could even see a 7-speed being an advantage. I use a very narrow RPM range (1200-2000). After swapping out my original transmission for the CRX HF one, I ended up raising my shift points in the lower gears due to the wider ratios. 20 MPH school zones are tricky for me. The engine lugs in 3rd, revs higher than I'd like in 2nd. So I try to coast the school zones.
I'd hate a 3-speed! My car would barely be drivable. I've driven older 3-speed trucks. I was always wanting a gear that didn't exist.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
wdb (10-15-2017)
