Old 09-30-2017, 04:19 PM   #8 (permalink)
2000mc
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
Originally Posted by gpfaster View Post
Once I have torque up and running I can do a wai and grill block. Need to see if I can find a serpentine belt for a/c delete. Was an option so I should be able to . Looking forward to seeing a small change in the mileage numbers!
I don't know how different the 01 is from my 99, but before blocking the grill I would say you'll want to duct your grill opening to the radiator or atleast install a factory air dam to keep the air from going around the bottom of the radiator.
Issue I had with wai was if I could get good heat on the highway it was too hot in town and would get preignition, never figured out a system to switch from hot to cold
I didn't bypass the ac compressor, when the ac is off, I don't think it creates any more drag than an idler pulley.
The Following User Says Thank You to 2000mc For This Useful Post:
gpfaster (09-30-2017)
