Old 10-02-2017, 03:16 AM   #1 (permalink)
Xist
90 day: 34.37 mpg (US)
Which timing belt (kit) should I purchase (survey) 99 Accord
Also, what else should I replace while I am in there? I planned on replacing the seals, but which ones? Crank and cam shaft? I have read water pump, tensioner, and pulleys. that I need to remove the serpentine belt, so I should replace that as well. What else?
Thermostat?
Rockauto has Dayco, Continental, and Conitech kits with water pump and seals for $76 - $126
Thank you very much! Have a great day!
