Old 10-02-2017, 08:21 AM   #2 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Gates. Anything else is a waste
Replace
Rad cap
Coolant
Thermostat
Upper/lower rad hose
All timing belt tensioners (gates kit will include these).
Timing belt.
Front main seal/crank seal(only if it's leaking. Otherwise leave it alone).
All drive belts (AC/ALT/PS, it's probably all one belt).
Why replace all this stuff? Well, doing this job is kind of a ***** because it's a FWD car. Would hate to see you blow the engine because something cheap like a 5$ radiator hose bursts.
The Following User Says Thank You to Baltothewolf For This Useful Post:
Xist (10-02-2017)
