I think when I tried to do ground with ground and top with top I got the first image at the start of the thread, and that didn't seem to work
. Unless I am missing something in which case I apologize!
I wouldn't over-think it. Have you looked at the fore-aft profile of The Template?
I'm not entirely sure I'm so new to aero moding that even that makes me confused lol.
At any usable truncation, the best you can do is produce the existing contour rearward and inward with a boxed cavity or concave bulkhead. I would limit vehicle length to 18 1/2ft based on the length of a parking space.
That sounds great, but it also is much more difficult to do
. Others had suggested just tapering off the boat tail quicker which would be easier but much less ideal I'd guess?
The chevrolet express I used to own was 224.1÷12=18.675 Feet long, and I could park it just about anywhere so your suggestion on length is spot on.
There are examples of hitch mounts on Ecomodder. Leaving a gap between the box and car body is similar to the separate bed on a pickup truck — a drag inducing feature. It might be better to use a non-reciever hitch and gain additional attachment points at the old taillight locations.
I was really hoping to get a smooth transition of the boat tail from the end of the rav4 onto the boat tail body. I will have to think about how to tackle this. I really would like to have some reliable storage space in the back. My Rav4 EV is usually pretty loaded. If I could load about 3 good sized boxes in the back I would be quite happy. Though I feel like I'd need for the storage are to reliably hold up to 100 pounds. Not sure if I could design that right which makes the cargo carrier interesting. There is an aluminum one in harbor freight that weighs 30lb. Doesn't seem too heavy?
Anyway, since I am so confused on which template out of the 2 I linked earlier is right I settled to check the dimensions on the 1st which has the longer boat tail.
Pixel Check:
65 390 front bumper
635 390 rear bumper
570 pixel difference
rav4 ev is 180" long
570÷180=3.166666667 (1" equals about 3.166666667 Pixels)
Boat Tail Length?:
635 395 tip of rear bumper
980 395 tip of boat tail
345 Pixel Difference
345÷3.166666667=108.94736841"Inches/12"=9.078947368 feet long boat tail
9.078947368−20% (Fluid Tail Reduction)=7.263157894 Feet long Boat tail 80% of full size.
And if I want to stay within your suggest length, which is about the length of a Chevrolet Express non-extended:
7.263157894÷2=3.631578947
180(rav4 length)/12"=15(Feet)+3.631578947=18.631578947 Total Feet
So I would have to cut the boat tail in half and design a slide out cone tail thing of sorts I can deploy before going into the highway. Half version for city driving and 80% of full boat tail for highway.
